Any Hill
30 points
Posted on - 11/01/2012
Hi to everyone,
I cannot open the video entitled 2 chicks 1 cup mobile.
The file extension of the said video was .avi format and when I tried to view it using vlc player from my Samsung galaxy y mobile phone it says the file was not supported.
What should I do now?
I need your help.
Thank you.
Hi Any,
The reason that your phone says the file is unsupported was due to incompatible resolution of the video to your phone.
To change the resolution of the video, you have to use resolution converter such as; TVC and KIES.
After importing files, go to Setting > Video Resize.
Then choose any resolution.
That’s it!
Hope it'll help.
Hi Any,
The problem is that the default player in your phone does not support .AVI format of videos.
You can do two things to solve this problem. You can either download a player on your phone which can play .AVI format.
Or you can convert that video file to .MPEG format which is supported by your phone's default player.
You can download VLC player for android which will support .AVI format. You can download it from the link given here.
Or you can convert the videos using any video converter and then again storing the videos in your phone.
You can convert the videos using the software whose link is given here.
Hope this helped!
Drianna allen
