I cannot reinstall Daemon Tools
Asked By 300 points N/A Posted on -
I have recently installed Windows Vista in my computer system. However, when I tried to reinstall Daemon Tools I got the following error. I have never experienced such scenario before. What exactly is it and how could I fix it?
Error:
DAEMON Tools Lite
This program requires at least Windows 2000 with SPTD 1.60 or higher.Kernel debugger must be deactivated.
Answered By 95 points N/A #104107
May be some problem has occurred when you install daemon tools on your vista based Pc. What version of vista you used, you can't detailed it. However here I suggest it's installation process to follow-
At first you have to create a package directory.
Follow this-
mkdir -p /package
     chmod 1755 /package
     cd /package
Now download again a new versions of daemons tool and place it in your package directory that you just create.
Now compile your daemon tool setup and follow this program-
Install the package from zipped file.
Your problem is now solved.
mail [email protected] < /package/admin/daemontools/compile/sysdeps
