Sam Draker
20 points
Posted on - 06/21/2011
Hi All,
I am Sam. I do have a problem with my computer. Well, mainly on my browser. My computer is running on Windows XP and I am only using Internet Explorer as my default browser.
First of all, I have to tell you that aside from Internet Explorer, I do have Mozilla as well. My problem occurs, whenever I am filling up form in the internet. After completing it, I am getting an error when I try to submit it. It says that I am unable to send the HTML forms as my current settings will not allow it. I have tried this in Mozilla and it is working.
Please help me on how to sort it out using IE7.
Thank you.
I cannot send html forms using Internet Explorer
You may have to send the forum by this way I am suggesting you.
First of all open the internet explorer and then click on tools.
A drop down menu will be appear now click on the internet tools.
Then click on the security tab from the tools and click on the custom level.
When you click on the custom level set it to miscellaneous.
Then select any of them:
Prompted for approve before proceed. And click on the prompt.
Skip the programming and automatically reject the action and select the disable.
Automating proceed without prompt.
Other method is:
Open internet explorer and click on tools.
Click on internet option and click on security tab.
Click on the internet zone and then custom level button.
After this scroll down to miscellaneous and set non-encrypted form date disable to enable.
Click on apply and press ok.
It will work.
Thank you.
