bluendyel08
20 points
Posted on - 07/28/2011
Hi there I need to send mail using my MS Outlook account but I keep on getting this error:
!Task bl**********@yahoo.com: Downloading folder list. ' Report error (0x80070057): An unknown error has occurred saving any existing work and restart the program. Could not complete the operation.
One or more parameter values are not valid.
What does this mean? How can I fix it?
Kauzie
I cannot send mail in my MS Outlook account
Well it is not a serious matter or anything to worry about many people does not know about it as it is not known much to people therefore let me tell you 1 thing clearly that Yahoo is a POP3 server and not HTTP.
Moreover in order to have the permission to use Yahoo mail through a POP3 email client you need to purchase it only then you will be able to use Outlook or Outlook Express.
Otherwise you will use it through the Internet, that is, by going onto the Yahoo website and further than going to Yahoo mail.
Good Luck!
Hello Bluendyle,
The error you face there simply means that the Microsoft Exchange Server is corrupted, or either the tasks folder in the server is corrupted. The best solution for this is opening the outlook window and doing the following steps;
1. Opening the task folder in 'Simple list' view.
2. Clicking a Save task order on the actions menu.
You need to have the current view in order to set to the 'Simple list' or 'Current list'. Another method if that doesn't work is;
1. On File menu, click 'Exit' and 'Log off'.
2. Go to Start button, click Run and type 'exchnge32.exe' in open box click ok.
This error message could be brought about by a number of problems.
1. Incorrectly configured mail servers.
2. Registry errors.
3. Antivirus restriction.
To resolve this issue try one of the following solutions.
1. Ensure your mail servers are configured correctly. If you are using POP3 In particular make sure you check 'My outgoing server requires authentication'.
To do this click on 'Tools-Email Accounts-View or change existing email accounts-"Change" button-"More Settings" button-Outgoing Server tab'.
2. The error could also be brought about by registry having a small size limit. You need to do a registry clean up using either tune up utilities or ccleaner. Alternatively you can increase the size limit by following these steps.
In Control Panel, double-click System.
Click the Advanced tab, and then click Performance Options.
Under Virtual memory, click Change.
In the Virtual Memory dialog box, change the registry size.
You can also sort this by downloading and installing this file
MDAC 2.7 SP1 from this website.
Just ensure your windows is genuine before you try this.
3. Your antivirus could be blocking access thus returning the error. Try disabling your antivirus. In most you can disable by the right click feature on the antivirus icon.
I have read your problem, no need to be much worried about this error.
I think your parameter is not correct, it is about to be referred because of wrong spelling of commands or functions or there might also be a possibility that you may have worms or bugs in the programming, or it can also be possible if you can turn on the caps lock on your keyboard.
What I mean is when you type your password you will get the error that your caps lock is on, so to overcome this problem you need to be less sharp while typing your commands and functions. One other reason is that sometimes it also happens when you try to copy large files like of 750 MB.
I think I give you a suitable answer to your question or for further details click the link below:
https://support.microsoft.com/en-us
