I cannot start Flir R&D software
When I start FLIR R&D software it pops up with the following error message stating “Application failed”.
Can you please suggest me how I can deal with this error or handle this problem?
Error:
Application failed
Cannot create internal object.
Answered By 15 points N/A #103280
Flir, R&D software is support in medium configuration desktop or laptop. But you are getting an error to start or run it in your computer.
I am seeing from your screenshot that you are used Windows Seven operating system in your computer. But windows seven does not support a lot of software to install and maximum important software are not run in that operating system.
So I highly recommend you to change your operating system from your PC to avoid this type of problem.
This type of problem may occur for unavailable access administrator in any PC. So it is must important to have administrator access.
Thanks
