I Can’t Boot My Computer Because My ACPI Sys Driver Is Corrupted
Mention the solutions to fix the corrupted ACPI sys driver. What are the reasons behind the occurrence of the error code?
The unwanted file, virus, or malware in the system makes the driver corrupted, or any unwanted application may become a reason behind the occurrence of the error code.
The solutions to fix the error code are:
Solution 1:
Restore the Computer to the latest restore point
Click on the Start button and type “System Restore” in the search box, then press Enter. Find System Restore and click on the System Restore. Now, enter the administrator password and follow the wizard to restore the system to the latest fresh version.
Solution 2:
Run Startup Repair
Step 1: Boot the system with a Windows recovery disk.
Step 2: Follow the installation wizard, then click on Repair your system to enter the Windows recovery environment.
Step 3: Navigate to Troubleshoot >> Advanced Option >> Startup Repair.
Solution 3:
Wipe and reinstall from the Recovery Partition
