I can’t delete a file with 0 bytes
I created a MS word file and when I want to delete it says "Unable to locate the file".
But I can see a file and it has 0 bytes.
What can I do ?
What can I do ?
It may be probably due to disk corruption.
For disk corruption follow the steps below:
1. Double click on My computer
2. Right click on C: and select Properties > Tools > Check Now
3. Tick Automatically fix the file system errors and then click Start
4. Click Yes to schedule the check on the new restart
If its not working try renaming the file and then deleting
Or in command prompt window using DEL filename and then use an unlocker which may help resolve the problem.
Now you can check to see if your zero byte file still exists, but I think the steps will work out well.
If do not know how to use command prompt use dir /?
To see a list of commands you can use
Hope I was able to help.
Notifications
