I can’t download anything from my computer. I am using Mozilla Firefox version 5. Yesterday, I tried to download any file like exe file or rar file. It asked for download location. When I gave the location, it stated that download failed.
What is the problem here?
I can’t download anything in my computer
Have you tried to scan your computer for viruses? Or check your firewall? If you already tried these steps and it still didn't work, open your browser and then click Tools> Internet Options> Security Tab and then under the Custom Level Button scroll down to Downloads and then Automatic Prompting for File Downloads. Click to Enable and then click OK.
Well, if you are facing problem with downloading, there might be multiple solutions around:
First of all, clear the download history of Mozilla Firefox.
Try to change the download location of your downloading,
If there is antivirus problem, stop your antivirus and then try again.
Check your download options if there is any restriction that is not allowing you to download exe or attach files.
Finally, if you are using any download manager, uninstall them, then reboot your PC.
Your problem will be solved. It’s because your download manager is not registered.
I also experienced the same problem. I am very thankful to Iqbal_imran.
