I wanted Sims 3 to be installed in my computer, but every time I click the set up there is an error.
I don't know what kind of error this is. I wanted this game badly.
Could someone tell me what could be the problem?
I have a Windows 7 Professional.
>SetupNewsetup.cpp (140)
PAPP:
PVENDOR:
PGUID:
@Windows Vista Service Pack 0 (6000)
IE Version: 8.0.7601.17514
paul25
I can’t install Sims 3.
The Sims 3 is a social game. There are many causes of your game is not running.
Firstly check the CD is ok.
There could be some data missing. Missing data might be the cause of your problem. Change your CD from where you bought the game. Change the game and ensure that the CD contains all the data.
The Game is around 7 GB (not exactly) in space. If your game CD contains this much space and the game still no running then change your windows (If you want to play the game badly). Changing windows can solve your problem.
I think you have got your answer.
The game you are installing is not compatible to run in Windows 7.
If you want to install The Sims 3 and play it in your computer you need to replace your current operating system with either Windows XP or Windows Vista.
The Sims 3 only supports Windows XP, Windows Vista and Mac OS operating systems.
Here are the minimum hardware requirements for The Sims 3:
For Windows XP
Windows XP Service Pack 2
Pentium 4 2.0 GHz processor or higher
1GB RAM
128MB video card with Pixel Shader 2.0 support
DirectX 9.0c
6.1GB hard disk space plus 1GB additional free space for custom content and saved games
For Windows Vista
Windows Vista Service Pack 1
Pentium 4 2.4GHz processor or higher
1.5GB RAM
For Mac OS X
Mac OS X 10.5.7 Leopard or higher
Intel Core Duo processor or higher
2GB RAM
ATI X1600 or Nvidia 7300 GT with 128MB video RAM, or Intel Integrated GMA X3100
Note: This game will not run on PowerPC (G3/G4/G5) based Mac systems, or the GMA 950 class of integrated video cards.
