I can’t login to my youtube account? What’s the problem?
I am trying to login my YouTube account. But I can't. What's the problem?
My family member can login to their accounts using their own laptops.
But I can't.
They are using same IP.
But I can't.
First of all, Try to create a new account on your family member PC's. If you cannot, then your IP address may be temporary banned from creating accounts.
If you can, then may be your MAC address has been blocked. Take your laptop to any of your friends house and see if you are able to create an account.
Or, You can try deleting all of your cookies and creating a new account with a different email address.
Hope this will helps.
What is the error message?
This would help us determine the problem and the correct solution.
It is not a big problem don't be tensed about that you just create the account on YouTube and it requires the email id when you are filling the form of YouTube account creating and when you create the account on u tube just go to your email address which you have mentioned in your form then check mail which you received from YouTube click on the link of this mail your account will be verified and after verification you will not face the problem
Thanks
Notifications
