I cant make an Aircraft Without the Template Button
I bought the latest version of Super80, but I can get text-o-matic to work. While I was installing it, I made it a point to install the text-o-matic at the root folder. All features seem to work fine when I run it, except the template button and I can't make an aircraft without it! Here's a screenshot of the error:
RegSvr32:
The module ''COMDLG32.OCX'' may not compatible with the version of Windows that you're running. Check if the module is compatible with an x86 (32-bit) or x64 (64-bit) version of regsvr32.exe.
Does anybody know how to make it work?
Answered By 5 points N/A #139043
Base from my experience to this problem, some components of the program may not install successfully. To fix this one you need to download the OCX and register it to your system 32. To do that, follow this.
  1. Download comdlg32.zip here. windowsxp.mvps.org/utils/Comdlg32.zip
  2. Extract it, and put the comdlg32.OCS to C:WindowsSystem32
  3. Run command prompt then type
            regsvr32  %Systemroot%System32comdlg32.ocx
            Then press enter.
 If this doesn’t work to your computer, you might need to try to install it using the compatibility mode.
  1. Right click the installer.
  2. Click properties then click Compatibility tab
  3. Check the checkbox “Run this program in compatibility mode for”.
  4. Select operating system and service pack installed to your computer.
  5. Click Apply button, then click OK button.
   If those solutions didn’t work for you, might problem with operating system compatibility.
