Jelena36
10 points
Posted on - 09/07/2011
Oh I can't think of anything. What should I do for this?
I can't use MS Word 2007 in my computer.
But it's urgent. I recently installed MS Office 2007 on my personal computer.
I can open all the packages without MS Word. When I open Word 2007 the message below appears.
It says There is not enough memory or disk space to run word
Then I deleted some files from my C: drive. But unfortunately it didn't resolve my problem.
Then I re-installed the full MS Office package again. But it occurs again and again.
This is very urgent for me to open the MS Word and work with it these days.
Please give me a solution.
Sam753
Not enough memory error to run MS Word 2007
Your facing a critical problem. There are many reasons why the problem happens.
It might be because your PC RAM is not as good as it should be.
You need good configuration to run the Microsoft Office Package like MS Word.
Or, it might have problem in the CD/DVD of Microsoft Office.
You can change the disc from the store (where you used to buy the CD/DVD).
Replace the disc and try to install newly on your PC. Or, you can re-setup your Windows.
Re-setup your Windows will solve the problem.
You can use Windows 7 32 or 64 bit.
I think you have got your answer.
I think the problem here is inadequate disk space.
And added to it is the available RAM memory in your computer.
You did not mention anything about the RAM capacity of your computer and the available free space in your hard drive.
If you installed Microsoft Office 2007 and the available hard disk space in your computer is just enough for the program to be installed, then the error message is just right.
You have to have a considerable disk space for the program to work.
Even if you have an average memory capacity in your computer, your program will still work because of the page file.
It will share the memory load from the RAM memory to your page file located in your hard drive.
Try the following solutions:
Few things can cause this from corrupted Office install, to a corrupted document file, do you have the Office CD/DVD handy?
Is this new Install of Office 2007 or has Office 2007 has been working up to this point?
Try opening Word in its Safe Mode, Click Start>Run and paste WINWORD.EXE /a. If it works then there's a likelihood that there incompatible 3rd party add on, this we can cross if it works in its safe mode.
Also another thing is to try Office diagnostics this can be run from any Office product.
kerubo
When search a problem occurs on your computer try to do the following in order to resolve the problem:
Open the windows explorer.
Click on File then choose options.
When options opens, click on the Add-ins.
Look at the bottom of the open dialog box that is written Manage.
Make sure the MS Office CD is inserted into the CD-ROM. Then select the COM Add-ins and select Go.
You will have to deselect the Microsoft Office Live Add-in and then click ok.
Restart the PC and try to open MS Word 2010 again.
Hi
Error because you don't have enough free space on your hard drive. Anyway, also pay a visit this Techyv link for more information.
Not Enough Memory Space when running MS Word
