Damian2
Posted on - 09/13/2011
Greetings,
I have been recording songs on my DELL laptop for a while now as it helps me play back and review the content. I have been doing that through the "mic input" on my laptop, but now I want to record the songs through my mic using the" line input" on my laptop. However, when I try to do that, it brings this message. Please advise.
Adobe Default Windows Sound Driver
Device: Conexant HD Audio input
Errorcode: FF9-5-0044 [80004005]
Info
Device could not be opened
Much appreciation.
I can’t record songs using the “line input” port of my laptop
I need to know which company’s sound card you are using. If it is realtek sound card then I need to know how many outputs have with your realtek sound card. If you have three of more than that then open your audio driver and configure other output port and select it for output. It will solve your problem by just activating only one of the multiple stereo outputs.
And if you have only one output then deactivates all inputs and configures one of your input ports as output. It will solve your problem.
Other option is go to control panel and then add or remove program and then uninstall this software and then reinstall this software again.
