I have palm centro with Verizon I could not picture out how to connect it into my yahoo messenger, and when I clicking into my yahoo messenger home page the link pop up called messenger information when going to yahoo homepage only give link called messenger information probably you should download it to the mobile.
Help me anyone. Thanks
I could not connect Verizon to my yahoo messenger
Well, you will not be able to access yahoo messenger on your phone until you have installed it. You will just need to click on the yahoo messenger link in your browser and search for yahoo messenger and download it. Since the default search assumes that you need a yahoo messenger to be used on a computer, you will need to specify the system specs of your phone so that you get the right one.
Note that you cannot download a yahoo messenger application that is meant for another phone and expect to work on yours. Since it is a Verizon phone, ensure that you search for a yahoo messenger that can be used on Verizon phones.
Chalk Talk
Hello Heidi Goodwin,
I have read your issue on how to connect your palm centro with Verizon with Yahoo messenger. I had experienced the same issue before also. The palm centro lets customer access AOL's AIM service, MSN Messenger and Yahoo! Messenger. Is Yahoo Messenger the only problem on your palm centro? If you can access the other applications from your phone then you must be able to use Yahoo as well.
From these applications you need to download the Yahoo Messenger function to your device. Then this can fix your problem and you can also start using your Yahoo Messenger.
