I’d like to make Jquery banner flash image in Firefox
Is making jquery banner flash image in firefox possible? I'd like to make a flash banner in jquery using Mozilla Firefox 18.0.2 My system has Windows 8. Would it also work in Firefox?
Hi Willie Stout,
It is very possible to make jquery banner flash image in Firefox. The flash banner may align itself exactly where you set it to be in Firefox. The images are retrieved in HTML through a normal unordered list. A separate CSS is obtained when the jQuery plugin is downloaded. You can use this CSS if all elements are well positioned and call it when a browser that is being used corresponds to it.
The jQuery banner flash image would also work in Firefox but in a different way. A simple edit of surrounding elements perhaps resetting the ul s margin of the browser may make the flash image align well on different platforms.
