Mickhel
70 points
Posted on - 10/10/2011
I have a  simple mobile, brand Symphony x100. It is so nice & I like it very much. I found some problems in it, I can't find any option to use it like a modem. I want to use it with my PC to communicate to the network but I did not find any software or an option to use it.
How could I use it like a modem ?
Jess
Choumen
5 points
I do not find any software or option
Hello Mickhel,
Don't worry, you of course will be able to use the Internet from your PC using Symphony mobile as your modem. For doing this you read the following outline below:
Make sure that you are using Symphony x100.
You have used Internet by using it before.
Now you have a Internet connection on to your mobile phone.
If you are sure that all are correct for your mobile device then go to the link below where you can download the PC suite for your Symphony x100 mobile phone.                   Â
You need to download and install it onto your PC for using your phone as a modem.
Hope this helps you.
Good Luck!
Choumen
