I don’t know how similes that moving inserts for emails
Hi
I need to know that how can I insert an moving smiles into my e mail massage. I need to send a mail to my little sister and It should be attractive.
Thanks
Hi
Thanks
Hello Maria,
          Moving Smileys which are mostly known as Animated Emoticons, can easily be added to your email using there repository. The following Link provides you Animated Emoticons for free
       Just Browse the categories to find a smiley you wish to enter in your email, You just need to copy paste the Url of smiley you wish to enter
Shwanj WhudsonÂ
Hi Maria.
Putting Smiles in our e-mail messages makes our e-mail attractive and personalized. We call this smiles emoticons. Emoticons are facial expression represented by a picture. To put emoticon in your e-mail message, follow this steps:
1. In your E-mail account, click "Compose Message" then select "Emoticon" tab.
2. The different "Emoticon" will appear then you may now select the emoticon you want. and it will appear on the message box. About the moving smiles, there are emoticons that moves automatically when selected.
Try, so that you can see. I hope I helped you with this.
