I need a list of Exchange Event IDs’ because I’m planning to add them on our list for some alert notes. The problem is I don’t know where to get it. I haven’t tried using Microsoft because I think they don’t have one.
Please suggestions or give opinions.
I don’t know where to get List of Exchange Event ID’s
Hello Clark Anthony,
Below are the list of exchange ID's which you can use for alert notes:
Even ID 677 – This is about the security failure audits
Nethelp msg commands
Error types
Troubleshooting Template
Windows log in processes
Managing firewall challenges
How to obtain fix
Search for information
Auditing policies
Kerberot options
Remote event logs
And you can find a lot more on this site http://www.eventid.net/documents.asp
In the application log, there should be events log in. Use trigger when your back up succeeded. I hope that this solution helps you solve your issue. I also need exchange ID's before and I just get to that site.
-Zorian
