I downloaded amiga cursors for Windows.
Hi to everyone,
I downloaded amiga cursors for windows.
After I installed the amiga cursor it was not working and doesn’t take effect in my mouse pointer cursor.
What should I do now?
The installation process is successful, how come it does not take effect?
I hope you can explain the main reason.
Thank you.
Best Answer by Howell Jessica
Answered By 0 points N/A #178997
Hi Chloe,
After Downloading Amiga cursor, these steps should be considered:
  • Cut and paste the folder into My Computer > Program files C: / > Windows > Cursors then exit.
  • On the Desktop, click Start > Control panel > Classic View > Mouse
  • At the bottom middle part above the "ok" button click browse.
  • locate the Amiga cursor in the Windows folder under Program files C: /
  • Select any cursor that you want. (Only cursor in .ani format will work)
  • After selecting, click "ok"
And that's it!
Answered By 0 points N/A #178998
Uninstall the “Amiga cursors” by going to the “add or remove programs” which is present in the Control Panel.
Select the software i.e. “Amiga cursors” and click uninstall/change and follow the guided procedure.
After that, install the “Amiga cursors” software again, this will solve the problem.
If this didn’t solve the problem, there must a compatibility issue with the windows version/ operating system you are using.
