I downloaded a flying text on desktop.
Hello friends,
I downloaded a flying text on desktop. How to install the downloaded flying text on my windows 7 64 bit operating system computer desktop?  The location of the installer is at the downloads folder. What will I do next to have a successful installation process?
Thanks and Regards,
Emaily Rawa.
Answered By 0 points N/A #179514
Hi Emaily,
-First, check if your downloaded flying text meets with the requirements of your OS Window 7. If not you are unable to use it as it is.
-Second, run the installer, commonly the .exe file as administration.
-When you run the application, it will automatically install the way by itself so you don't have to do anything but to accept all query it give.
-Then that's it!
Answered By 590495 points N/A #310253
If you want to install the program, first, make sure your computer meets the requirements before installing it. You can get the system requirements from the website where you downloaded it. If the program’s specifications are not listed there, try searching the system requirements on Google. Since you are using 64-bit Microsoft Windows 7, make sure the program supports 64-bit.
If the program is not compatible with your computer, you cannot install it. Also, don’t forget to scan the file with your antivirus to make sure it is not infected with a virus. If you verify that the program is compatible, open Windows Explorer then navigate to the download folder where the installer is located.
To install the program, just double-click the installer to launch setup then just follow the instructions. If you are not familiar with the program, make sure to read every page in the installation to avoid installing bundled applications.
