I downloaded free hotel booking script.
I downloaded free hotel booking script. Unfortunately the sample script that I downloaded from the internet is not compatible with my netbeans 6.9 version. It cannot open the file sample, what would be the possible answer for this kind of problem?
Waiting for your support, thank you.
Best Answer by Wiedemann Alecia
Answered By 0 points N/A #174531
You wanted to use the hotel booking script that you downloaded for free from a internet source. You said that is a sample. However, as your netbeans doesn't support the sample, you'll have to change the version or get a new sample that opens in the existing netbeans. You can also try to open the script in notepad and then rename it in PHP.
Answered By 0 points N/A #174530
In here you want to download free hotel booking script.
I think you can use “Hotel Reservation System V 2. 0.
This will show the 8 item named Room Type, Add Booking, HR History, Current Booking, Old Booking History, Room Statistics, Search Rooms.
You can use this item and I think these can fulfill your desire. You also can add/remove item from this version and will be updated in future.
