After logging in to PCSchool, I encountered this error prompt:
Please enter a valid date prior the PCSchool does the run.
Error
Technical Details
Error Number 16
line Number 56191
I encountered this error prompt when logging in to PCSchool
Check again the settings of the application. The error could be an incorrect option in the settings particularly the synchronization between your computer’s calendar with the application.
Check the date settings in the application if it matches with the current date in your computer. If it does not match, try changing it to the correct date settings.
The application should automatically update its calendar every time it’s accessed. But if it does not do this and it keeps on loosing the date settings, try uninstalling the application and then install it back to fix any corrupted files in the installation and to restore its settings back to default including some that you might have customized.
You may also try checking your computer for any possible errors. Use a disk utility application when checking the system.
