I encountered an error when I tried to close the AutoCAD
Maybe you could help me identify the problem I been going through for updating our engineers. I have specifically encountered one problem with it.
I have also tried rebooting it and the AutoCAD 2012 LT seems to be working so very fine for quite a while. Maybe it runs well for one or two hours. But how come I encountered an error when I tried to close the AutoCAD and tried to open it again?
AutoCAD LT Error Aborting
There is a problem with the installation and AutoCAD LT cannot
continue.
This error may occur if the registry cleaner software has
removed or altered registry keys that are required to run AutoCAD LT.
To restore the required registry keys, you will need to reinstall
AutoCAD LT using the Add/Remove Program functionality in the
Windows Control Panel.
        OK
Can you please help me check this out and find a way to perfectly run it?
Answered By 10 points N/A #156392
Hello Tammy,
You will need to check the following:
  • The kind of application that is on the computer that is performing the registry edits. Check if you disabled that.
  • You will need to set the application as well as the antivirus you are using so that it will ignore AutoCAD as well its files and activities.
Try uninstalling the .NET program that you have on your computer. Ensure that you get rid of all .NET programs from Windows, and after that restart and then reinstall the ones that are needed only. You might as well just update your Windows fully.
Carl
Answered By 590495 points N/A #310777
One possible cause is if you previously used a registry cleaner and it accidentally removed entries in the Windows registry related to the AutoCAD program. If this happens, AutoCAD will start to malfunction or will not work at all. To fix the problem and restore all the important registry entries required by AutoCAD, you need to reinstall the application.
Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your AutoCAD among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer.
When it is finished, close Revo Uninstaller then install AutoCAD back. This should fix the problem. If this doesn’t work, try to download any available patch for your AutoCAD version.
