I experience electric shock from PC each time I try using it
Hi Janice,
Your problem seems to be static electricity in your body. Static electricity is created when two nonconductors rub against each other. Electrons and being transferred from one body to another thus becoming static electricity.
This electrical potential then discharges with proximity to another conductor (e.g. Your PC) and depending on the humidity of the air between you. Â
Hi Janice Emond,
To add more about the previous comment, static electricity or Electrostatic discharge (ESD) from your body can destroy the small electronic components in in a computer.The CPU and chips are vulnerable to ESD. Even if you don't feel the static electricity being discharge from your body it is always there. So its better to for you to use an Anti-Static Wrist Band like in the picture below to avoid further damage.
It is available in most electronic or computer shops.
Hope your informed with this. If you have any questions don't hesitate to ask.
Thanks
