I Face A 0x80070422 Xbox Error Message
What is the 0x80070422 Xbox error? Explain the cause of the error and tell the steps to fix the error and also attach a snapshot of the error.
0x80070422 Xbox error indicates that some of the services the Xbox App uses have not been enabled or not working clearly. This will results in sign trouble into Xbox Live through the App and other services of the Xbox can be effected.
The Steps to fix the 0x80070422 Xbox error are as follows:
• Go to Start -> Settings -> Apps -> Apps and features. Scroll down to Xbox, and select it. Click on Advanced option, and click on Reset. Restart the system and check the store for updates.
• Enables some of the Xbox Services
Step 1: Go to Cortana and search for MS Config.
Step 2: Open MS Config and on the pop up window, select services.
Step 3: Now, check the following boxes are ticked – especially Xbox Live Credential manager, Xbox Game Services/servers and Xbox Services.
Step 4: Select OK/Apply.
Restart the PC/Device.
• Try to open command terminal and type “Services.msc.” Scroll down to Xbox Services and select it manually or restarting it.
