I Face A 0x80070578 Error Message
What is the 0x80070578 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x80070578 error is the audio driver error, which is an “Invalid window handle” at the tail of the Full Backup. 0x80070578 error is displayed like: “The MACHINE_CHECK_EXCEPTION” bug, and this checks indicate that a fatal machine check exception has occurred. The symptoms of the error 0x80070578 are that the computer will be frozen up. The steps to fix the 0x80070578 error message are as follows:
• Verify the Volume Shadow Copy and Windows backup service is started.
Step 1: Click on Start and type “services” on the search box and press Enter.
Step 2: Scroll down and select Volume Shadow Copy and Windows backup.
Step 3: Start the services if they aren’t started.
• Run the System File Checker (SFC) scan to fix the corrupted files.
Hold Windows+ S and type cmd. Open a Command prompt and choose Run as Administrator. Now, type “sfc /scannow” and hit the Enter key. The scan will run and find the error, and it will automatically fix the error.
