I Face A 0x80090005 Bad Data Error Message For Creating A New GPO Service
What is the 0x80090005 bad data error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
0x80090005 bad data error occurs when the user deletes a protected file in Windows 10 OS. This error also occurs when posting a certificate to a Microsoft CA. The error message appears: “PostCSR failed with error: Bad Data. (Exception from HRESULT: 0x80090005).”
The steps to fix the 0x80090005 error message are as follows:
Method 1:
Perform a scan using Windows Defender.
Step 1: Go to the Start option, then go to Settings and open Update and Security.
Step 2: In the Windows Security option, select Virus and threat protection.
Step 3: Under the Current threats section, select Scan options.
Step 4: Select Microsoft Defender Offline scan, and then select Scan now.
Method 2:
Perform Disk Clean-up.
Step 1: Go to the Start option and type Disk Cleanup in the search box.
Step 2: Open Disk Cleanup and select the drive in which the Windows App Download is then clicked on OK.
