I Face A 0xc004f063 Error While The Installation Of Windows
Examine the 0xc004f063 error? Explain the error code briefly and show the steps to fix this error code, and add the snapshot of the error?
Error code: 0xc004f063 message shows, “The Software Licensing Service reported that the computer BIOS is missing a required license.” System file corruption, license key inconsistency, BIOS inconsistency, and licensing restriction are reasons behind the occurrence of the error code. The methods to fix the error code are as follows:
Method 1:
Contract with Microsoft’s support care.
Method 2:
Run the DISM and SFC scan.
Method 3:
Activate the Windows using SLMGR.
Step 1: Hold Windows Key + R to open the run dialog box. Give all the permission that appears on the screen.
Step 2: Open the command prompt and type the following commands:
• Slmgr /ipk <Windows Key>
• Slmgr /ato
Restart the system, and the error will be resolved.
