I face difficulty in establishing VPN using CISCO
I have done all the things I can to get rid of this problem. I re-installed the application several times and did all the possible troubleshooting. But it still gives me error. Are these caused by hardware malfunction? The screenshots are attached. Thanks in advance.
Error:
The VPN client agent has encountered and error.
Unable to establish VPN
Answered By 95 points N/A #135793
When you are using Cisco, then you have to checkout something before you starting. Is your connection is properly connected when you are trying? Your problem may be possible to have in your software. If it's registration period has been expired it can shows such of problems. If your software is valid,  then I think, problem has in your firewall.
At first disable your firewall and remove such program like anti-malware, unecessarry application from your system/server. Then try to establishing Cisco using VPN. If still the problem will not solved, I suggest you two sites, you can find out the other ways there: http://helpdesk.ugent.be/vpn/en/faq_cisco.php?id=429 and Cisco AnyConnect VPN Client Troubleshooting Guide
Hope for your best relief. Thanks.
