I failed to use Vodafone Mobile Connect Software.
Hello experts,
I failed to use Vodafone Mobile Connect Software on Windows 7 64 bit because of following error message:
Hello experts,
Hi Catherine,
It is not enough to just delete the said software. You need to uninstall it. But before you reinstall the software, you first need to update the Huawei Firmware. To do this, you have to download the E220 Software Upgrade.
Instructions are provided on how to install this software upgrade. After installing E220 Dashboard next thing you need to do is to upgrade the latest version of Vodafone Mobile Connect. Now, I understand that you have the Firmware and Drivers installed.
To install Mobile Connect, go this Site  for you to download the latest version the Mobile Connect. From this page, select the option For the PC (Windows). Then follow the instructions given.
Unfortunately, companies such as Vodafone seems a bit slow in supporting new OS such as Windows 7.
