I forgot my avast password 2011.
Hi guys,
I forgot my avast password 2011. How can I recover the antivirus licensed key or code, I reformatted my pc last night and was able to delete all the files from my local disks. Now the problem is I cannot recall where did I put my avast password 2011 information.
Expecting some help, thank you.
Best Answer by Hammer Shepich
Answered By 0 points N/A #179016
Hello Chloe,
You have come to the right place. We will be glad to provide you with solutions to your concern.
Are only having issues logging into Avast! Anti-virus Software or are you trying to re-install it right after reformatting your computer?
To recover your license key for your Avast Anti-virus, access the email account that you used to sign-up with Avast! Important details such as your License Key or code is usually sent to your email account upon registration. If you are lucky and able to access you email, then this resolves your issue.
I hope this helps! Feel free to get back to us if you still have questions in mind.
Answered By 0 points N/A #179017
Hi Chloe!
Regarding your inquiry about avast password recovery, you could actually search first online regarding about it. There are a lot of password recovery programs that you could find online. For instance you could use Google Chrome as your search engine. and just type "password recovery programs". Once you click search, there are a lot of choices to choose from at the websites. Then once you have choose already, just follow the necessary instructions that was indicated. If the solution that you choose will not work, it is best to uninstall Avast first then reinstall it again.
I hope that I have help you. Thank you!
