I forgot my Ms word doc file password?
Asked By 25 points N/A Posted on -
Hey guys,
I want to know how to get back my file accessible which is a doc file. Actually the thing is I forgot my doc file password which was saved by me only a while ago in MS Office 2013 and now when I tried to edit doc it is asking password to remove restriction but I forgot so please tell me how to recover my password? Or do I need to create another doc file.
Best Answer by Mmasi Whitney
Answered By 0 points N/A #187089
Hi Amelia , Yes .In the new office 2013 dropbox and google drive can be added . To add dropbox just follow the instruction1. Open the Registry Editor. You can open it in desktop mode by hitting Windows + R to open the Run As menu, typing Regedit into the box and hitting Enter2. Navigate to the HKEY_CURRENT_USERSoftwareMicrosoftOfficeCommonCloud Storage registry key.3. Create a new key under Cloud Storage name it 0627ecb4-3ede-422a-8b23-954e7b6bed29. You could use a different key name, as long as you generate it with the GUID generator.You can create a new key by right clicking on the Cloud Storage key, selecting new Key and renaming the new folder it creates.4. Right click in the right window pane and select String Value from the New menu. An entry labeled New Value #1 appears.5. Rename New Value #1 to DisplayName by right clicking it, selecting Rename and then changing the text.6. Double click on DisplayName and assign it a value of Dropbox (or Google Drive).7. Create another string value called LearnMoreURL and assign it the home page URL for Dropbox or Google Drive.8. Create a third string value named LocalFolderRoot and assign it the path to your Dropbox or Google Drive folder (ex: C:usersapiltchDropbox).9. Close Regedit and reboot your PC.10. Open Word 2013 and add a blank document.11.Click the File tab. Then open ->add a place -> select dropbox
Answered By 10 points N/A #187090
How are you? If you want to recover the password for your word document or doc file, you can do it easily by using Free Word and Excel password Recovery Wizard tool. The length of the password should be eight characters maximum. CrackIt is another software which you may use to recover the password of your doc file. Learn more.
Moreen Jamnelly
