I Forgot My Password. How To Change Router Password Cisco?
Hi, I am using a cisco router and cannot figure out how to change the password as I have forgotten it. How to change router password cisco?
First, connect the router to a wifi modem.
Then, open a browser on your computer for example safari or chrome. Open the following link: http://192.168.0.1/
If prompted for a password, use the following credentials:
● Username: cusadmin
● Password: password
Then, click on setup as shown in the picture below
Click on the option saying “pre-shared key” and check the box beside it saying “show key”.
Your current password will be displayed. To change it, remove that password and enter new one. Then, click on “save settings” which is present on the bottom of the page.
