Email Address not Found on TechyV website
I forgot my password but my email address is the same i received my mail from you but when i enter my email address the system says it is not found.
Techyv password forgot.
Dear, Its not that important. You can have a different account if you want. But you have to submit a different email address then. You can have all the facilities with the new account. If you want to find the older one please try to maintain the instruction given in case of account recovery. Thank you.
If you cannot recover your password here even if you requested it to be sent to your email, then just create a new account. Maybe there have been conflicts when you created your account here. If you really can not recover your password even if you requested it, create a new account. Since the system says that it can not find your email address on its database, then you are free to create another account.
You can create multiple accounts here but with different emails. You are free to post all your questions especially on computers. But don’t limit yourself to computers. You can also create your own blog here if you are into blogging. Feel free to explore the site.
TechyV.com has forgot password link if your log-in is not working. This tool allows you to reset your password by sending an email message to your email address. Here content attached to it is a copy of a password generated by the system.
The database will saved the email address you have used to registered for a single purpose, email capture for contacts.
Once you have registered, an email message from TechyV.com will send you a welcome message. This confirm your registration that it's created successfully and a greeting of congratulations.
If password is forgotten, a password reset tool is designed to re-generate new password. This will help you get a new password once you have pass all the security verification. TechyV.com will ask for your email address you have registered then a password will send to your account.
In your case, you have tried resetting it but the email address says incorrect or not found. You still have a ways to log-in back to your account here by contacting the Administrator. At the bottom of the page, you may click on contact us link and you need to fill-up all the necessary information to let the Administrator know that you have problem log in in. A brief description of the issue and message them your concern.
There is also an FAQ at the bottom that TechyV.com designed to provide answers of frequently ask questions. This is very helpful tools that give you tips and instructions of a specific problem, a good example is "Password problem".
It's quite an easy problem. Since you can open your email address, log in to its website and click login button. At the bottom part of the login page, you will see forgot user name or email address. Click it and enter your email address. Wait for a minute and check your email. They will give you your username and password.
