I forgot my security question
Hi Sanaabid,
On your Skype application you can click on problem signing in? This will redirect you to the Skype website. Put your email in that you registered with Skype when you setup your account. If you don't know your registered email, click on forgotten email it will redirect you to the accounts and setting page click on the request help page link. On the next page you can follow the links to contact help.
If you know your email address, then it's straightforward. Submit your email address, a temporary password will be sent to your email address, click on the link or submit the code manually. Young will be asked to create another password.
Hope this helps you.
