I found arcade 320×240 troublesome to play in my mobile.
I have downloaded several arcade 320×240 games.
But most of them doesn't working my mobile.
Is it could be due to some Java settings.
What am I missing.
Please enlighten.
What am I missing.
Please enlighten.
Hi Watson James,
You didn't mention the Mobile handset Model Number like, Nokia E71. But I suggest you. First of all check the specification of handset: Supported games Specification.
Always use the default Java setting for all games, which are supported, all games.
Always download the games from the Handset specified website. (Select the Handset)
I provide you the best website for Mobile downloading : http://www.mobile9.com
I wish this solution may be helpful. Thanks!
Best,
Fenster Maxine
