I found an error in the program “Clintfinder”
30 points
Posted on - 02/08/2013
I found an error in the program “Clintfinder” however I install and run it. What’s the issue with this error 603? Will somebody tell me what is this??
Unhandled exception has occurred in your application. If you click continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
The remote server returned an error: (403) Forbidden
