I Get An Error That Says – A Problem Prevented The Document From Being Scanned
I need help to fix the printer error on my Windows 10 PC – a problem prevented the document from being scanned. Restarting the printer did not work.
One of the following methods will help you to fix the error – a problem prevented the document from being scanned.
Method 1
a. Open PC Settings.
b. Open Devices Settings.
c. Click on Printers & scanners.
d. Remove the device that has an issue.
e. Add a printer or scanner.
f. The device will be detected.
g. Click on Add device.
h. Try to do your work now.
Method 2
a. Open the Windows Store.
b. Search for Windows scan app.
c. Download the app.
d. Launch the app to solve your problem.
Method 3
a. Press Windows + R on your device.
b. Type services.msc and press enter.
c. Double-click on the WIA service.
d. Change the startup type to automatic.
e. Start the service if not running.
f. Restart your PC.
g. You will not face any error.
Notifications
