I get BlueSoleil installation error 183.
I am trying to install BlueSoleil 8.0.338.0 on windows 7.
But while I was installing this an error 183 occurred. I can’t get rid of this.
So I need some help in solving this issue.
Hi there. Searched for your problem and finds the solution here. It will work. Try it.
Solution:
First you have to uninstall all previous versions of the blue soleil from your computer. To do this go to Add /Remove Programs and uninstall.
Now go to start/run/regedit a screen will open. Delete all the register key that is set to bluesoleil.
You can use this command to view all the keys of bluesoleil.
Edit/find/bluesoleil.
Select all the bluesoleil folders and files and delete them. And then run the disk cleanup utility and clean all temporary files of bluesoleil.
Restart your computer and run the setup again. It will be installed this time.
Solution 2:
If the above solution doesn’t work check your software version if it is 64 bit or 32 bit. May be you are installing the wrong one in wrong system.
Hello Cullen,
The first thing you will need to do is restart your system and then retry running the installation again. If the error persists then it is more likely that it is due to the following reasons:
Hope this helps.
Carl
Before installing BlueSoleil, make sure your computer meets the requirements. The latest version at the moment, BlueSoleil 10, supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. Microsoft Windows 10 is not officially supported. But since you said you are using Windows 7, there should be no problem. Also when installing, make sure the Bluetooth dongle is connected to the USB port.
Because BlueSoleil is the software or the driver for the BlueSoleil Bluetooth USB dongle, the Bluetooth dongle should be connected to the USB port so the software can detect it. If the dongle is not connected, connect the Bluetooth dongle first to the USB port and try installing the software again. See if it works. If this doesn’t work, try starting the installer as administrator.
Right-click on the BlueSoleil setup file and select “Run as administrator.” This should fix the problem. To download the latest, go to BlueSoleil Software.
