I get an error on the best WBFS manager 2011
Hello, Wii Backup Manager used to be the best wbfs manager 2011 for me because it works perfectly, until it gives me these errors:
split 0: size (-1) not sector (512) aligned wbfs
error: hd num sector doesn't match
Does anybody know how to fix it?
Thanks,
Sargent Franks
Answered By 0 points N/A #167824
Hello!!
I have confirmed about the matter. I am giving some significant solutions regarding this complex trouble.
You have to employ Wii Backup Fusion to rip the files into a .wbfs and .wbf1 file.
Then it will be seen that USB Loader GX boots up the streamer .
If the error occurs then you have to scan your hard disk drive for errors and the wizard will automatically fix all the errors.
Regards
Shifflett Laurel
