That error is probably from the last update of the game. First, check the system requirements again and verify your computer meets those requirements. “Rise of Nations” supports Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires 1.6 GHz or faster processor, 1 GB RAM, Microsoft DirectX 10-compatible video card (integrated HD 3000, 8600GT, or better), sound card, and 3 GB free space.
Rise of Nations: Extended Edition
If this doesn’t apply, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select “Rise of Nations” among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and click to delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then install the game back. For more information about the game, go to Rise of Nations: Extended Edition on Steam.
1....
