Why am I getting an error while installing Yahoo messenger? The error message reads "This application has failed to start because application is incorrect. Reinstalling the application may fix problem." I tried to reinstall it various times, but I get the same error message. Maybe I am missing something here? Please tell me what to do? Any idea what’s causing this problem? Help please
I get an error while installing Yahoo messenger.
Where did you get your yahoo messenger if you’re installing it from an installer try to install it from the internet. There are yahoo messengers that is not compatible with the configuration of your computer so try to check it first. If it will not download from the internet then configure your computer. And also check your default browser maybe it’s not installed properly. Try this step click default browser the apply maybe this will work. If this persist I think you should ask a technician to check it out for you huh? Maybe there is a problem with your computer parts. But try as much as possible to reinstall it maybe the internet connection is not that fast also. Many reasons are coming your way everytime you install a program in your computer and just try to solve it in every way possible.
