I got confused between Android and Cyanogen which one is the best
80 points
Posted on - 04/06/2015
Hello, I am getting confused between Micromax Yu and Gionee M2, because they have used two different software technologies. Which battery is used for both? Is Cyanogen OS better than Android v4.2 Jelly Bean? Please describe the Camera’s technology for both. Can I record HD videos by using a camera? Which processor is used for both? Thank You
