I got an error while setting-up the remote debugger
I got an error while setting-up the remote debugger I wanted to use on my Windows Server 2008 (non-R2),
And using my Visual Studio 2012.
I posted an image of it below.
Visual Studio Remote Debugging Monitor
The Windows Web Services installer failed to execute. The installer exited with error "Data of this type is not supported."
OK
Remote Debugging Configuration
Remote Debugging Monitor has detected configuration issues. The following configuration changes need to be applied before
the debugger can proceed.
![](https://www.techyv.com/sites/default/files/users/King%20Lopezs/1_13.jpg)
If anyone here was able to install the remote debugger 2012 on a non-R2 Windows 2008 server,
Can you tell me how?
