Hello Experts,
I got this kind of error invalid certification. When opening a Google chrome browser there is an error message that states about invalid certification. May I know what is the cause of this problem. Is it about the website that I am going to open or the internet browser that I am using?
Please give me some answer.
Thank you.
Dear,
You can uninstall and reinstall your browser and it should fix the problem. You can also update your browser or download the latest version if this doesn't fix the problem.
If you get this error when you try to navigate any web site, then the best solution would be to reinstall Google Chrome and if this is only for a particular web site then it’s related to Web Site certificates.
You’ll see a button “Proceed Any Way”. Click on that then you’ll be redirected to the web site that you want to view.
Hi
I will help you to resolve your problem. When you go to a website with expired certificate or invalid certificate, the browser shows a message that this certificate is not valid or invalid certificate. This is a warning that the site is insecure or very kind of fraudulent. Hope this helps.
