I got a problem after installing an application
I have problems in windows after installing Tune up Utilities. My anti virus software is not working after I installed it. I think there is a conflict between the softwares.
What am I gonna do?
What am I gonna do?
You are facing problem in using both tune-up and anti-virus . I think they cannot match with each other. Tune-up utilities maintain your PC very well. It is essential for PC. It solves problems in your PC. Anti-virus is another essential part of PC. It keeps you safe from viruses. But sometimes they conflict with each other.
You should delete those two software and re-install them. Hopefully they will not conflict each other anymore. Use a licensed anti-virus to keep away from this sorts of problems. Or re-install windows in your PC and re-install Tune-up and anti-virus.
Not all computer tune-up utility applications clash with antivirus programs. I have a Norton Antivirus 2010 installed on my computer and also once used a registry tune-up application together with it and they worked fine with each other. But there are applications that need to be installed in the right sequence to work and avoid clashing with other applications. Like for example, if you have a Norton Antivirus 2010 installed on your computer, you can install Norton SystemWorks 2010 or later but you can not install and pair it with Norton Utilities 2011. As what I have experienced, it will have a conflict on their product version timeline something like that and one of them might stop working. To solve this, you need to uninstall first Norton Antivirus 2010 and then install Norton Utilities 2011. After installing Norton Utilities 2011, you can now install Norton Antivirus 2010 again. It follows a certain hierarchy in their product version.
In your case, since your antivirus was already installed before you installed the tune-up utility application, try changing their installation sequence. Uninstall your antivirus and then install the tune-up utilities you have. After the installation, try opening it to see if it works fine with no problems popping up. After that, install again your antivirus. Observe if these 2 applications will work fine. Do some restarts on your computer to test if your antivirus will not stop launching during startup.
Always defrag your computer so that all the files are maintained and improve the access rate.
