I got a problem to oracle set up downloads.
Hello experts,
I got a problem to oracle set up downloads. I download the oracle database software and it seems like it has a problem with the set up because it is unable to open file indication when I try to access the software. I need your solution to resolve this problem.
Thank you.
Best Answer by Paul jolie
Answered By 0 points N/A #180229
If you submit a screenshot of your problem, it may help us to understand better. If your setup is not initializing or is interrupting in the middle of installation then; check compatibility of the software and your OS. Check the PC configuration. The setup software may damage or corrupted. Download again the well-matched version.
Answered By 15 points N/A #180230
Hello Anthony,
Your question is too much confusing and you couldn’t clear it properly.
Are you sure that you have the complete file? Male sure that you have the complete oracle database software.
To recover the issue, at first you need to download a oracle database software which is compatible with your operating system. Before set up, you should turn off all anti-virus activities. Then set up it as administrator. After that, do a clean restart.
Hope your problem will be solved.
Thank You.
