I got some connection error with the IP address 129.105.203.9
I am working for a company similar to Google Maps. I trace the addresses of my customers online.
When I am trying to use the application, I got some connection error with the IP address 129.105.203.9.
Please fix the error so that I can continue to work.
Failed to connect to WHITEHALL or address 129.105.203.9 on port 28203
Answered By 10 points N/A #195095
Hellow Joycedparker,
Follow this instruction:
   > Press the Guide button on your controller
   > Go to Settings
   > Choose System Settings.
   > Choose Network Settings.
   > Choose Wired Network or the name of your wireless network.
   > Choose Configure Network.
   > On the Basic Settings tab, Choose IP Settings.
   > Choose Manual.
   > Choose IP Address.
   > Enter the unique IP address that you made up, and then select Done.
   > Choose Subnet Mask, enter your computer's subnet mask, and then select Done.
   > Choose Gateway, enter your computer's default gateway, and then select Done.
   > Choose Done.
   > Press B on your controller and then test your connection again.
   Hope it will work.
Regards
Franke Mary
