I got some problem about mac block google images. I cannot control the mac operating system from blocking some images from google.com website. When I tried to download some images it will not respond and never resume the downloading process. I need some help.
Waiting for your support, thank you.
I got some problem about Mac block Google images.
Hi Deborah.
1. The first thing to do is make sure that your connection doesn't have a download limit. Some internet connection plan have a fixed amount of data one can use for downloads. This may be happening as a result of the amount of data being exhausted.
2. It could be your firewall preventing downloads from the site. Check your firewall settings to fix this.
3. It could also be the browser you are using. Uninstall and re-install this browser and see if the problem persists. You can also try downloading and using other web browser applications.
I hope this fixes the problem.
