Hello friends,
I got some problem with my pizza order script php. Do you have knowledge about any online websites that offers tutorials about php scripting? I made a small system for pizza order business and was having trouble about the administrator database. I need some help.
Thanks and Regards,
Kathryn Masud.
Hi Masud, thank you for asking that question. There are a lot of sites
where you can get tutorials on php scripting. You could do a google
search for php scripting tutorials. Here are sites where you can
get some:
www.w3schools.com/php/default.asp
www.htmlgoodies.com
You can also search youtube for videos on php scripting tutorials.
I hope I’ve been of help.
I have two favorite tutorial sites for PHP that I highly recommend.
PHPClasses
This site contains tutorials for beginners and for intermediate students. The tutorial is comprehensive and I assure you that after a week you can develop PHP scripts independently. It also helps that the site has PHP scripts example for you to study, tweak and test. They also provide book reviews of PHP published books that are very helping in enhancing your study.
PHP Manual
For extensive learning, this is a site for you. All you needed to know about PHP is here, from basic simple tutorial to advanced topics. I like the part' wherein the interface with the user is simple and clean. You can easily navigate the site and is very procedural.
Taylor
If you are using CodeIgniter as web application framework you can try tutorials from this site https://www.codeigniter.com/docs
There are step by step tutorials for everything you need to create web applications. Also on this site you can find database configuration, how to connect with database and a lot of other things. Just click above on table of contents and pick the topic for tutorial you need. I hope this will help you.
There are many websites which provides online tutorial of PHP.
Below are the site names from which you can get your all solutions.
www.tutorialspoint.com/php/
php.net/manual/en/tutorial.php
www.freewebmasterhelp.com › Tutorials › PHP
www.php5-tutorial.com/
See below site to get more idea.
https://sourceforge.net/projects/restaurantmis/
